Help with curent limiting
jombom
Joined Apr 4, 2024
I need to use a 3.7v battery and the input of the device is 2.8v max curent of 350mA how do I limit the curent the easy way?
ericgibbs
Joined Jan 29, 2010
21,573
Hi jom,
Welcome to AAC.
What is the device that requires 350mA at 2.8V.
It may be possible to insert a couple of diodes in series with the 3.7V source.
E
jombom
Joined Apr 4, 2024
I'm trying to power a laser diode it operates at about 2.6 to 2.8v at full power and it can't take more than 350mA I could do with 300mA
Externet
Joined Nov 29, 2005
2,676
The easy way ? A 3.7 V battery can be 4.2V after just charged. Say 4V. Use two >1A silicon diodes in series:
(+)3.7V to 4V ------------------|>|----------|>|-----------------near+2.6V ----------------laser----------------common(-)
Unless you prefer a voltage regulator IC.
jombom
Joined Apr 4, 2024
How about something more complicated to have a constant voltage output as the battery voltage drops?
BobTPH
Joined Jun 5, 2013
11,654
A buck-boost regulator with a current limit adjust would be ideal, giving you the longest battery life. There are inexpensive boards that do this widely available. You would set the voltage output to something higher than needed, say 3V or more, and the current limit to 350mA.
MrSoftware
Joined Oct 29, 2013
2,273
There are multiple possible solutions, are you looking for the best or most efficient solution, or the easy button? You can do something like combine the LM3102 voltage regulator with the LM8646 current limiter. There are other solutions, this was just the first to come up in a search. Here's the LMP8646, the datasheet has a complete example circuit for what you're looking for on the first page. There is an evaluation board that is a complete circuit, check it out to see if it meets your specs or can be easily modified to meet your specs.
38,825
There's not a lot of overhead between the battery voltage as it discharges, and the Laser diode forward drop, so I would go with Michal's circuit in post #11. which requires <0.2V, with the Laser current being constant as the battery voltage drops.
28,312
How about something much simpler like a series resistor to drop the 4.0 volts to 2.8 volts when the current is something less that 350 mA?? Then as the battery voltage drops the laser power will drop a bit also.
38,825
Below is the LTspice sim of Michal's circuit (with a few tweaks):
It shows a constant Laser Diode current (yellow trace) for a battery voltage (green trace) above about 3V.
The Laser Diode voltage is about 2.6V (red trace) at 310mA.
So the circuit with the parts shown, will give a constant-current to the Laser Diode with a battery voltage down to about 400mV above the diode voltage.
