attached is the truth table i can get for alarm to function......anyway, i don`t really understand it to wellOh, and you still haven't a column to your table identifying the inputs and output(s).
Very good! You are realizing that you might not have enough information to solve the problem.yea,he said for the engine to running,the key must be in the ignition.
but funny enough,the lecturer didn`t state if the car will be in motion or not not OR that the engine will be off when the key is in the ignition
telling the lecturer the question is not complete might be disastrous you know.Very good! You are realizing that you might not have enough information to solve the problem.
Sometimes ambiguous questions are asked to see if the student knows enough to know that's the case.telling the lecturer the question is not complete might be disastrous you know.
Is what you posted in your first post the exact wording of the problem?when i read the question again..i became confused.........any way out?
Understand....just ask the lecturer "is the motor running when the key is on"telling the lecturer the question is not complete might be disastrous you know.
The lecturer should justifiably question the intelligence of the person asking the question and suggest an alternate career.just ask the lecturer "is the motor running when the key is on"
Sorry...I disagree...If the lecturer does that...the lecturer should be looking for another careerThe lecturer should justifiably question the intelligence of the person asking the question and suggest an alternate career.
I have been told many times that there are no dumb questions, but, in reality, there are; and that would be one of them.Sorry...I disagree...If the lecturer does that...the lecturer should be looking for another career
First, is there anything that all of these conditions have in common?A car ignition system is designed to function such that an alarm comes on whenever any of the following occur;
a)when the engine is running while the door open.
b)the door is open while the headlamp is on.
c) the key is in the ignition while the door is open.
how can i design a combinational logic circuit whose output goes high to trigger the alarm system whenever either of the conditions come up?
state all asumptions.
kindly assist.
heh...well..does the engine auto start when the key is turned on?I have been told many times that there are no dumb questions, but, in reality, there are; and that would be one of them.
For this problem, I'm sure it does. The problem is to teach students about boolean equations, not how to design a car ignition switch functionality.heh...well..does the engine auto start when the key is turned on?
Forest for the trees man, forest for the trees...
What does it matter?heh...well..does the engine auto start when the key is turned on?
Exactly. That was pointed out in the first response.What does it matter?
Condition #3: If the key is in the ignition while the door is open, the alarm is supposed to sound. Does it matter whether the engine is running or not?
Which is exactly what I suspect was the expectation.Exactly. That was pointed out in the first response.
The OP could choose to include the redundant expression in the solution or simplify it out by stating his/her assumptions.
I have answered this once. No. The question is correct and solveable.apparently,does it mean the question is not correct or unsolvable?
For simple problems like this, just reading the conditions solves the problem; but won't necessarily give the simplest expression. A Kmap makes obtaining the simplest expression easy and using one couldn't be considered wrong or misguided unless the instructions prohibited their use.With all due respect to my colleagues here, their suggestions to use kmaps may be misguided.
