Hello everyone, first time posting and I’m desperate for help. I was recently gifted a Shakespeare 606 wondertroll. 6v or 12v. I believe it was made somewhere in 1960-1970 and is 18lb thrust. The problem I’m having is a complete power dump when switched into forward. Everything is operational and perfectly fine in reverse. When switched to forward, it stops, and will melt wires. Learned that through trial and error. I can’t find any info online, so I’m looking to anyone here with knowledge on this motor. I’m not very good at all with electronics or motors. I have replaced all the switches, there is a on/off a switch to control speeds (low, med, high) and a toggle for forward and reverse. The motor is good, it runs when I hook it directly to the battery. I also notice the prop spins in the same direction no matter if it’s hooked directly to the motor or through the wiring in reverse, it seems like it’s spinning in the forward position.
