help with 555 timer
starrz
Joined Jan 6, 2013
17
hey everything is up and running, connected the relay and transistor but am not getting the latching effect when output two is high, the leds and well as of now relay, sticks when output two is connected to clock disable without even going high at all, as long as i connect any output whatsoever to clock disable it just sticks on, you said yours latched properly?
tracecom
Joined Apr 16, 2010
3,944
I have the entire circuit built, including the relay. It works just like I described in post 30. When I disconnect the power and reconnect it, output 0 goes high for 2 seconds and the relay operates, then output 1 (which is connected to nothing) goes high for 2 seconds and the relay releases, then output 2 goes high, the relay operates and stays operated until I disconnect the power and reconnect it.
Did you put the 1N400x diode across the relay coil?
ScottWang
Joined Aug 23, 2012
7,509
You can't connect LED to the output of CD4017, because it may make BJT not enough current to drive the relay.
R5 can be reduce some more to 8.2K or 6.8K, some relay maybe draw too much current, so you should measure the resistor of Relay coil, and use I_relay = 12V/resistor_relay to calculate that how much current the relay would need.
tracecom
Joined Apr 16, 2010
3,944
Here's a crappy video of the circuit working.
http://youtu.be/QZ8TbJLyk18
In the video, the green PCB standing up is the 555 clock; the green LED on it indicates a high output from pin 3. It's running faster than you want, but I already had the circuit built.
The three LEDs on the front of the breadboard indicate three outputs from the 4017: green = 0, yellow = 1, red = 2.
The blue LED on the rear of the breadboard indicates an ON signal being sent to the relay.
The relay is shown in front of the breadboard. If you listen closely, you can hear the relay operate: soft click = operate, louder click = release.
