Help:vhf front end
hamopp
Joined May 13, 2009
68
Hi All.
I have a circuit of a 2m rx front end which works well, the output is fed
into a 9mhz if stage.
What i would like, is to be able to have this circuit modified to work in the
4m(70Mhz) and 6m(50Mhz) bands, I know that some components will have
to be changed and i have marked the parts with a * .
The front end coils in the 2m one are from Coilcraft (146-04J08SL), i also
have these coils from them:
2x 146-06J08SL 6.5t
2x 146-07J08SL 7.5t
2x 146-08J08SL 8.5t
2x 146-10J08SL 10.5t
data at http://www.coilcraft.com/uni7.cfm
Can anyone help with the values of the parts that need to be changed.
Regards
Howard
bertus
Joined Apr 5, 2008
22,995
There are basicaly two resonant circuits you will need to adapt:
L201 / C203 and L202 / C204.
You can use the formula for LC circuits for them:
hamopp
Joined May 13, 2009
68
Hi
That all looks like greek to me hi hi.
Can you please explain in laymans terms as
formula's like this are hard for me to understand.
Maths is a sore point for me.
Howard
Dodgydave
Joined Jun 22, 2012
11,395
Hi
Howard
If your going to halve the frequency of the receiver from 144Mhz to 70Mhz, you need to increase the inductance or capacitance to maintain the frequency resonance,
so either double the capacitance or the inductance to obtain half the frequency of the original tuned circuit.
t_n_k
Joined Mar 6, 2009
5,455
I would think that given there is a square root function involved it should rather be - "..... either quadruple the capacitance or inductance ..."
22,116
Hi
Howard
Funny thing about RF circuits. You can't dependably adapt a circuit up and down the RF spectrum without knowing a bit more of the "maths" and the "physics" than is readily apparent. For example, an active device, like a mixer or a transistor, designed to work at 144 MHz may not work quite as well on 6M or 4M. You also need some test equipment to adapt a design and verify its performance. What exactly are you going to do if things don't work as expected?
RF design is not for laymen. Hire someone who knows what they are doing. It will be less expensive and more efficient in the long run.
vk6zgo
Joined Jul 21, 2012
677
It seems you are a Ham--look around in your area for another Radio Amateur who can help you out.
I don't think you are going to be able to make one unit work on multiple bands.
Look around for designs for the bands you are interested in.
If you find a similar circuit for one of the bands you are looking for,you may be able to use some of the parts of the 2m one.
"Modification" from 2m to these other bands may entail that many new bits that it could take on the character
of "George Washington's original axe"--------It's only had 6 new handles & 3 new heads!:D
