Help on TRW215ESSDP, how to set to Celsius.
Avoid Avoid
Joined Feb 9, 2019
this is pcb board There is nothing written on the 32-pin microcontroller.
Someone can help me identify, I can read it in the programmer.
jpanhalt
Joined Jan 18, 2008
11,087
Even if you knew which MCU that was and could read its code (assuming it is not protected), the resulting hex file will not be much help. Sure, commercial entities have been known to even decap MCU's to get at the code and then have expert coders decipher it to steal IP. That is an expensive proposition.
It would probably be easier and a real kludge to read the data from the LED s and convert that to °C. The easiest approaches would be to find a controller that reports in °C or build your own. I doubt very much that the code in this device is particularly clever, but nevertheless, it is protected IP.
What do you need to control with it? Are you simply trying to get the wine cooler for which it is designed to report in °C?
If you can post an equally detailed view of the top of the board, there may be obvious pins or pads that can be used to program or read the MCU.
jpanhalt
Joined Jan 18, 2008
11,087
If that chip has had its ID erased, you are out of luck. There are lots of 32-pin MCU's available. Moreover, a manufacturer who would remove the label probably also protected the chip from being read.
