Help nuclear physicists student
Hellerx44
Joined Apr 6, 2021
52
Hi all
Nuclear physicists ( student) need help
I have a detector from ludlum company
(Ludlum model 2200) im using it to detect neutron particals. Im using snm-17 tube connected to my ludlum 2200 the working voltage is 1600 v dc . The issue is that there is too much noise coming from the russian detector. I need to separate the signal from the noise. schmitt trigger circuit for example will be nice.
Thanks in advance
wayneh
Joined Sep 9, 2010
18,169
Can you describe both the signal and the noise? I mean voltage, time properties. How different are they? If you saw an oscilloscope trace of the entire output, could you visually pick the signal out of the noise?
35,195
Instead of a Schmitt I would recommend a fast analog comparator such as LM311. What is the shape and height of the signal?
Assuming it is not a He3 detector, what is the SNM detector type?
