help needed dab radio with no sound
Tristan Curtis
Joined Aug 6, 2015
2
I have a few DAB radios which fully work without producing sound. I really don't know what could be causing this so need someone's help who knows what the common faults for no sound are.
The make is BUSH
GopherT
Joined Nov 23, 2012
8,009
@#12
I never came across that site before. Do you use it or did it just pop up today on a google search? Looks like a few of the AAC regulars are over there, too. I can't even keep up with one site.
12,273
IF the radio has two separate speaker amplifiers
THEN the problem is farther upstream. The odds of both speaker amps failing at exactly the same time are very low. The odds of a common power supply failure, mute signal miscue, etc. are much greater.
