Help need to install 12VDC motor on a boat
Kybandit
Joined Aug 24, 2024
8
I’m attempting a DIY project on my boat. I’m attempting to install a 12v DC motor, 2 independent 2 wire foot switches and a 3 wire speed reducer for the motor. I originally used a dpdt switch for testing purposes and it worked great but motor was turning a little quick for purpose. I’m a HVAC tech so I have good basic knowledge of voltage and controls but I find it easier working from a printed diagram. Any help would be greatly appreciated
Kybandit
Joined Aug 24, 2024
8
IMG_2935.jpegIMG_2936.jpegIMG_2937.jpegIMG_2938.jpegIMG_2935.jpegIMG_2936.jpegIMG_2937.jpegIMG_2938.jpeg
dl324
Joined Mar 30, 2015
18,465
Welcome to AAC!
It would have been helpful for you to include the wiring diagram for that setup.
Do you want the two SPST switches to use the speed reducer?
The thumbnails would have been sufficient. Less scrolling...
SamR
Joined Mar 19, 2019
5,535
Any time you run wiring through a bulkhead the hole needs to be grommeted to prevent chafing from vibration and eventual shorting. I also like to use a jacketed marine rated cable and not single wire runs. I also like to dope all connections with Liquid Tape, usually several coats, and shrink wrapped with adhesive interior wrap. And don't forget the fuses!
Kybandit
Joined Aug 24, 2024
8
I’ll rough this in then go back and make everything more permanent.
Kybandit
Joined Aug 24, 2024
8
Welcome to AAC!
When I first installed, I used a momentary dpdt switch. Worked great. But now I’m wanting to use 2 foot switches. Each switch is just a plain 2 wire switch.
28,258
Probably the motor will run a lot slower when it is spinning the prop in water. And for he wires passing thru the drilled holes, if you seal the opening around the wire with silicone RTV, it will prevent chafing wear and water-proof the opening at the same time.
