HI can anybody help me understand some of this code which i dont get,, i qouted the part which for me needs explanation, but im still in the process of understanding all of this its for our project,,please help me
Rich (BB code):
* Project name: Programmable Digital Timer
* Copyright:
(c) Rajendra Bhatt, 2010.
MCU: PIC16F628A
Oscillator: XT, 4.0 MHz
// LCD module connections
sbit LCD_RS at RA0_bit;
sbit LCD_EN at RA1_bit;
sbit LCD_D4 at RB4_bit;
sbit LCD_D5 at RB5_bit;
sbit LCD_D6 at RB6_bit;
sbit LCD_D7 at RB7_bit;
sbit LCD_RS_Direction at TRISA0_bit;
sbit LCD_EN_Direction at TRISA1_bit;
sbit LCD_D4_Direction at TRISB4_bit;
sbit LCD_D5_Direction at TRISB5_bit;
sbit LCD_D6_Direction at TRISB6_bit;
sbit LCD_D7_Direction at TRISB7_bit;
// End LCD module connections
sbit MODE at RA2_bit;
sbit SELECT at RA3_bit;
sbit ENTER at RA4_bit;
sbit START at RB0_bit;
sbit RelaySW at RB3_bit;
// Define Messages
char MSG1[] = "Device is ";
char MSG2[] = "OFF";
char MSG3[] = "ON ";
char MSG4[] = "HH:MM";
unsigned short HHMM_Pos[] = {6, 7, 8, 9, 10};
unsigned short ON_Time[] = {0, 0, 10, 0, 0}; // 10 + 48 is :
unsigned short OFF_Time[] = {0, 0, 10, 0, 0};
unsigned short Mode_Select = 0 ; // 0:ON, 1:OFF
unsigned short i, j, k, Timer_On, Get_Input, Cur_Pos, Cur_On;
unsigned short temp, refresh, Num, HalfSec, Blink, ChangeMin=0;
unsigned short OFF_HH, OFF_MM, ON_HH, ON_MM;
void Disp_First_Row(){
Lcd_Out(1,1, MSG1);
if (RelaySW == 0) Lcd_Out(1,11, MSG2);
if (RelaySW == 1) Lcd_Out(1,11, MSG3);
void Disp_Char(unsigned short col, unsigned short chr){
Lcd_Chr(2, col, chr+48);
" void Disp_Time(){
for(i=0; i<5; i++){
if(!Mode_Select){
Lcd_Out(2,1, MSG2);
Disp_Char(HHMM_Pos,OFF_Time);
if(Mode_Select){
Lcd_Out(2,1, MSG3);
Disp_Char(HHMM_Pos,ON_Time);
void play_sound(){
Sound_Play(2500, 500);
void debounce(){
Delay_ms(250);
void cursor_left(){
for(j=0; j<5; j++){
Lcd_Cmd(_LCD_MOVE_CURSOR_LEFT);
void disable_timer(){
INTCON = 0x00;
RelaySW = 0;
INTCON.T0IF = 0;
Timer_On = 0;
Blink = 0xff;
Mode_Select = 0;
Disp_First_Row();
Disp_Time();
play_sound();
void interrupt() {
Num ++; // Interrupt causes Num to be incremented by 1
if(Num == 9) {
HalfSec ++; // Increase sec
Num = 0;
Blink = ~Blink;
if (HalfSec == 120){
HalfSec = 0;
ChangeMin = 1;
TMR0 = 39; // TMR0 returns to its initial value
INTCON.T0IF = 0; // Bit T0IF is cleared so that the interrupt could reoccur
void main() {
CMCON = 7; // Disable Comparators
TRISA = 0b00111100;
TRISB = 0b00000001;
Sound_Init(&PORTB,2); // Initialize Buzzer o/p pin
RelaySW = 0;
Timer_On = 0;
Get_Input = 0;
Cur_Pos = 0;
Cur_On = 0;
refresh = 0;
Num = 0;
HalfSec = 0;
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_Out(1,1, "Copyright @");
Lcd_Out(2,1, "Embedded-Lab.com");
i=0;
while(i<4){
debounce();
i ++;
Disp_First_Row();
Lcd_Out(2,4,"-");
Lcd_Out(2,12, MSG4);
Disp_Time();
do {
if(!MODE && !Timer_On){
debounce();
if(!Get_Input){
Mode_Select = ~Mode_Select;
Disp_Time();
if(Get_Input){
if(!Mode_Select){
OFF_time[Cur_Pos] = OFF_time[Cur_Pos]+1;
temp = OFF_time[Cur_Pos];
switch (Cur_Pos){
case 0: if(temp > 9) OFF_time[Cur_Pos]=0;
break;
case 1: if(temp > 9) OFF_time[Cur_Pos]=0;
break;
case 3: if(temp > 5) OFF_time[Cur_Pos]=0;
break;
case 4: if(temp > 9) OFF_time[Cur_Pos]=0;
break;
Disp_Char(6+Cur_Pos, OFF_time[Cur_Pos]);
if(Mode_Select){
ON_time[Cur_Pos] ++;
temp = ON_time[Cur_Pos];
switch(Cur_Pos){
case 0: if(temp > 9) ON_time[Cur_Pos]=0;
break;
case 1: if(temp > 9) ON_time[Cur_Pos]=0;
break;
case 3: if(temp > 5) ON_time[Cur_Pos]=0;
break;
case 4: if(temp > 9) ON_time[Cur_Pos]=0;
break;
Disp_Char(6+Cur_Pos, ON_time[Cur_Pos]);
} // END if(!MODE)
if(!SELECT && !Timer_On){
debounce();
Get_Input = 1;
if(Cur_On) {
Cur_Pos ++;
if (Cur_Pos == 2) {
Lcd_Cmd(_LCD_MOVE_CURSOR_RIGHT);
Cur_Pos ++;
if(Cur_Pos > 4) {
Cur_Pos = 0;
cursor_left();
else Lcd_Cmd(_LCD_MOVE_CURSOR_RIGHT);
if(!Cur_On) {
Cur_On = 1;
cursor_left();
Lcd_Cmd(_LCD_UNDERLINE_ON);
if(!ENTER && Get_Input){
debounce();
Get_Input = 0;
Cur_On = 0;
Cur_Pos = 0;
Disp_Time();
if (!START && !Get_Input){
debounce();
switch(Timer_On){
case 0: play_sound();
Timer_On = 1;
OPTION_REG = 0x07; // Prescaler (1:256) is assigned to the timer TMR0
TMR0 = 39; // Timer T0 counts from 39 to 255
INTCON = 0xA0; // Enable interrupt TMR0 and Global Interrupts
INTCON.T0IF = 0;
Mode_Select = 0;
Blink = 0;
Disp_Time();
break;
case 1: disable_timer();
break;
if(Timer_On){
OFF_HH = OFF_Time[0]*10 + OFF_Time[1];
OFF_MM = OFF_Time[3]*10 + OFF_Time[4];
ON_HH = ON_Time[0]*10 + ON_Time[1];
ON_MM = ON_Time[3]*10 + ON_Time[4];
switch(Blink){
case 0: Lcd_Chr(2,8,' ');
break;
case 255: Lcd_Chr(2,8,':');
break;
if(!OFF_HH && !OFF_MM &&!RelaySW){
if(ON_HH || ON_MM){
RelaySW = 1;
Mode_Select = 0xff;
Disp_First_Row();
Disp_Time();
play_sound();
else {
disable_timer();
if(!ON_HH && !ON_MM && RelaySW){
disable_timer();
play_sound();
if(ChangeMin) {
switch(Mode_Select){
case 0: if(OFF_MM == 0 && OFF_HH>0){
OFF_MM = 59;
OFF_HH -- ;
else if (OFF_MM >>0) OFF_MM --;
OFF_Time[0] = OFF_HH/10;
OFF_Time[1] = OFF_HH%10;
OFF_Time[3] = OFF_MM/10;
OFF_Time[4] = OFF_MM%10;
break;
case 255: if(ON_MM == 0 && ON_HH>0){
ON_MM = 59;
ON_HH -- ;
else if(ON_MM >> 0) ON_MM --;
ON_Time[0] = ON_HH/10;
ON_Time[1] = ON_HH%10;
ON_Time[3] = ON_MM/10;
ON_Time[4] = ON_MM%10;
break;
ChangeMin = 0;
Disp_Time();
}while(1);
