Help me make a tester like the "Led Keeper"
Status
Not open for further replies.
OldNewb
Joined Jun 8, 2014
9
Has anyone reverse engineered a "Led Keeper" tool. Here is a url to a short youtube video showing a guy using one. I have a tester I can use for the "fuse" test and the "single led" test so I am only interested in the part that helps locate the bad led fast. I'm thinking it might simply just has a 9 volt battery and a momentary switch with at least one lead wire having a wire insulation piercing conductor. Any schematics? Any advice is appreciated! ...........................Thanks
GopherT
Joined Nov 23, 2012
8,009
This will fall under a frequently encountered roadblock at this site. The site owner has decided that any projects using mains power, and transformerless power cannot be discussed (emphasized with a second rule that specifically says no mains powered LEDs.
absf
Joined Dec 29, 2010
1,968
There is something wrong with the schematics in post #1. 110V goes into the stacking plug and 110V comes out of the socket. The test circuit is in parallel with the AC. If you're not wearing rubber gloves, you'll get a shock when clipping the alligator clip on the wires.
May be 110V is not harmful enough, but think of the 240V that are being used in Asia and Europe.
Allen
ScottWang
Joined Aug 23, 2012
7,501
The topic was violated the rules of Transformer-less power supplies, so this thread will be closed.
6. Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will result in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Any kind of jammers (ie - Phone jammers)
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
If You come across a thread or post discussing any of the above topics please report the thread so We can close, and if necessary remove, the offending thread/posts.
User Agreement.
Status
