Help me choose combination
Eartian
Joined Sep 16, 2021
58
Hi all, I have a confusion over choosing combination. I have scenario where I need to measure SPO2 reading from a photodiode. So here should I use a op-amp and amplify and feed it to a stm32 or use a HX710b and feed the digital signal to the stm32. Which one will be robust and reliable and can do repeated readings perfectly?
KeithWalker
Joined Jul 10, 2017
3,625
Either of your stated choices, and many other electronic configuration could be made robust enough to give repeatable readings, depending on the accuracy and resolution you require. The main problem will be how you are going to position the sensor to give reliable repeatable results.
Eartian
Joined Sep 16, 2021
58
Either of your stated choices, and many other electronic configuration could be made robust enough to give repeatable readings, depending on the accuracy and resolution you require. The big problem will be how you are going to position the sensor to give reliable repeatable results.
I need high accuracy and resolution, either way I can use IIR filter and do that I guess. But the thing which you said 'the position of the sensor', I didn't get this. Can you please elaborate it?
KeithWalker
Joined Jul 10, 2017
3,625
You didn't mention whether you are measuring the O2 levels in a sample or on a live subject.
