Help, I have this Power Inverter which has a black cable an a black an white cable
MaxHeadRoom
Joined Jul 18, 2013
30,885
Is this power in or power out? Generally the stripe is common or -ve, neutral etc.
If output, just measure it.
More details on the inverter???
Max
Da11dab
Joined Apr 20, 2020
10
Is this power in or power out? Generally the stripe is common or -ve etc.
Max
No it’s the input have looked in book on website an nothing tells me just tells me not to connect them to the wrong inputs
Da11dab
Joined Apr 20, 2020
10
The following page states this :
Supplied with 12V plug socket connection cable.
https://www.streetwizeaccessories.c...ze/Power/Inverters/150-Watt-Inverter-SWINV150
The plug must have neeb cut off.
Bertus
Yes I want to
Bertus
yes it did have plug which I cut off does Say in book can connect to battery but I think you will now tell me cabel isn’t man enough
MaxHeadRoom
Joined Jul 18, 2013
30,885
Unfortunately there is no defined standard except:-
For AC inputs supplies, the stripe refers to the Neutral conductor,
When used on the DC side (output) , but ironically many specify the stripe as positive when used on the DC side.
Max.
Da11dab
Joined Apr 20, 2020
10
Max.
I no I not sure witch one to go for lols I’ll maybe give them a call
ericgibbs
Joined Jan 29, 2010
21,651
hi,
All the cables of that colour and white stripe tracer I have seen/used, the white stripe is the positive lead.
I would connect the white stripe to positive.
E
MaxHeadRoom
Joined Jul 18, 2013
30,885
The white for positive is generally (but not always) on DC low voltage conductors, if AC then neutral.
https://www.ecmweb.com/national-ele.../code-qa-identification-of-circuit-conductors
The use of alternating current means that power cords have "hot" and "neutral" wires, rather than "positive" and "negative.
" If you have a polarized appliance cord, the neutral wire is identified by a white stripe, ribbing or white insulation.
Max.
Da11dab
Joined Apr 20, 2020
10
Well thank you everyone for your help so in the end it turned out to be the positive thanks again for your help
