Help for component identification
sumeryamaner
Joined May 29, 2017
117
On the attached picture you can see the blown component. It is designated as EC4. There is another similar component as EC4. On this component (a diode???) are the letters "AA8G".
I am very unfamiliar to those SMD components and their designations. Can someone tell me what these two components (EC4 EC5) are? Thank you...
sumeryamaner
Joined May 29, 2017
117
Thank you very much. The two are connected across the positive supply and ground at the input and output of the regulator so they are probably electrolytic capacitors.
steveT1968
Joined Aug 18, 2018
10
Agree, EC makes a cap more likely. From my understanding of the code, A is manufacturer (no idea who), A is 1, 8 is 10^8pf, no idea of G. So that works out as EC5 being 100uf, EC4 may well be the same.
Remove the short on the pins at the bottom first though.
