I'm a power systems guy who usually don't like electronic circuits, but right now only them can save me. I'm finishing my new place where I'll be using a lot (to me) of 12V and 24V power supplies to power lighting. Normally I'd use only a toggle switch to power it on and off as necessary, but since I'm using some zigbee drivers to power it I've to let the PSUs connected or I'd lose the ability to turn on and adjust the drivers/strips. That brings me two problems due to the time they will be on even thought the light is off (95% of the time it will be draining some power to power it's own circuit and the driver) that are higher bills and smaller lifetime to the PSUs.
I've thinking about it for quite some time and yet to understand how can I improve it. For the last days my idea was to use some kind of circuit that, based on the current drained by the driver, it switches between a bigger and a smaller DC source. If the current is under some threshold it's powering only the driver and maybe a much dimmed strip, being possible to power it with only an AC DC power module of 5W or less. But if it's draining more power it switch to a bigger one, with enough power to use the lights in full power.
That's the best way to do that? There is some kind of circuitry that I could use? Or this is just a really dumb idea?
![1717985702391.png 1717985702391.png](https://forum.allaboutcircuits.com/data/attachments/311/311874-7fe325deb4c42982aaf5e6018d9394fe.jpg)
