hi all, i have some problem to my project. the block diagram here
as you can see, SM connected each other by two pin out of half brigde. 1 : mid of two mosfet 2: negative of capaciter
so, when implement, i use ir2103 to driver two mosfer, when i run each SM is ok but when connect them together i have problem.
so, pin COM of IR2103 above connect Vs of IR2103 below and circuit not run.
anyone can give me a suggest.
thank you verry much and i'm sorry for my bad english.
