GetDeviceInfo
- Joined Jun 7, 2009
- 2,285
Because you are supply your trans with 230vac, code will want you to ground your secondary, unless application exempted.Thanks for the great explanation. I decided not to bond the center tap to earth. Maybe i can create a seperate earthing for my project. By the way, can i use schottky diodes inplace of FER Diodes?
