Help About Center Tap Transformer
johnb01
Joined May 31, 2017
If I use one end of secondary wire and a center tap to create power supply,
can I ground the another end of the secondary wire (unused) or use a wire cap to be floated?
If I should ground, better to tie with the center tap??
Dodgydave
Joined Jun 22, 2012
11,395
From 7 to 1 the resistance increases and these wire are primary wires.
I live in Pakistan. i did bachelor in telecom. i am using this transformer in ups. i am feeding 220V 50hz at primary. At secondary i am getting 12V. this transformer is center tap.
i also attach some more pictures.
1-7 are the Primary windings, the thicker wires on the other side are the output, if you want more voltage out, use 1-6 as primary, or use 2-7, .
It's probably designed for 0-250v in steps.....
R!f@@
Joined Apr 2, 2009
10,004
It depends on your rectifier configuration.
4 diodes without the center tap or 2 diodes with the center tap ?
johnb01
Joined May 31, 2017
For instance, if I want to make a single end 12v power supply out of this transformer, I`m wondering for the another end, which is supposed to use for -12v line. If I short it with the center tap, that would destroy the transformer by drawing too much current?
How would it be difference btw 4-diode configuration and 2-diode one?
ian field
Joined Oct 27, 2012
6,536
If you ground anything other than the CT - you're confined to half-wave rectifiers.
ian field
Joined Oct 27, 2012
6,536
I am not sure whether this counts as half or full wave but as far as the transformer winding is concerned it is full wave. It has one end of the winding grounded.
Its a half-wave split rail supply.
With a CT secondary & 2 more diodes; you can have FW split rail.
Tonyr1084
Joined Sep 24, 2015
9,744
This drawing shows two ways to hook up a transformer. The first is a transformer without center tap. Assume for the sake of argument it's a 12 volt output. The second is a transformer WITH center tap. Assume for the sake of argument it's a 24 volt output with center tap. From top and bottom leads (in the picture) you get 24 volts. BUT the center tap to either leg is going to be 12 volts. This is the situation where you can use just two diodes. Both drawings will produce the same sine wave.
ian field
Joined Oct 27, 2012
6,536
3 ways - add 2 more diodes to the CT secondary and you have a negative O/P as well.
bertus
Joined Apr 5, 2008
22,943
As Ian told you two extra diodes and a buffer capacitor and you will have a dual voltage powersupply.
Here is a random schematic with an example:
Bertus
