ok cool. So I'm planning on plugging it into a IPad charging brick via USB. Pretty sure it's 12V 2.1A output. Will this be sufficient or should I just use batteriestypo, sorry, its supposed to be D2
ok, and do I need 2A, or could I go lower and still be fineThat brick will get hot fast. Batteries will be drained fast. 2A is a lot of power, try to find another source to power up your project.
Less than 2A and your solenoid may not work as desired. If you cannot find proper power source, try finding different solenoid that requires less power.ok, and do I need 2A, or could I go lower and still be fine
Check your inbox. Save $5 for your self.Ok. I'll start this build on Wednesday and if it's works I'll give u da $5. What's ur PayPal
Shoot one more question haha. Are the resistors 1/4 watt or 1/2 watt?View attachment 107960
very close to 2 sec on / 2 sec off.
D1 can handle 3 A, and Q1 can handle 2 A. Use heatsink on Q1
$20 and I will build it for you (you pay shipping and cost of parts).J/K, you can buy parts and assemble it your self..
1/4W and you need a base resistor for the transistor. The schematic shows PNP, but you need NPN.Are the resistors 1/4 watt or 1/2 watt?
