HC-05 using PIC16F877A
clarelluffyjjang
Joined Jun 8, 2017
35
Hi guys, i am currently doing a project to let microcontroller communicate. The microcontroller used must be PIC16F877A or PIC16887 only. I want to configure one of my HC05 as master and another one as slave. But i am stuck as there are no example in internet that config HC05 using microcontroller.
I have done a function in C code using MPLABX that define the role.
void BT_set_role(unsigned char mode)
BT_send_module("AT+ROLE=");
BT_send_char(mode + '0');
BT_send_module("\r\n");
in my main function i will put BT_set_role(1) to make the module master. But the problem now is that how can i make them paired automatically and send date? how to create the function with AT commands in it to make them paired when i power up the circuit? How do i know whether are they paired ? any function that can response to me is paired? i dont know how to write the function for send data receive data paired them? pls help
spinnaker
Joined Oct 29, 2009
7,830
Took me about 10 seconds of searching to find this.
http://elecfreaks.com/store/downloa...rail module AT commamd set 201104 revised.pdf
See paragraph 2 and 28.
