HB100 doppler radar IF output after pre-amp
Rickpercy87
Joined Nov 20, 2015
18
With reference to the below small datasheet:
https://www.limpkin.fr/public/HB100/HB100_Microwave_Sensor_Application_Note.pdf
I have created the two stage pre-amplifier and it appears to work great. I have paired it with matlab and generated script which logs the data. However, I have found that the IF output from the amplifier (10,000 times greater than input) is 1.6V and It fluctuates slightly depending on the doppler effect on the radar module.
Can anyone explain why the output is 1.6V? I imagine it would be much, much lower and would only fluctuate when movement was detected.
The reason being is I have just fried my 16bit ADC converter by inputting those very large values and amplifying it again by 8. OOPS!
Thanks for reading!
Regards
Rich
ericgibbs
Joined Jan 29, 2010
21,649
hi 87,
There is a Vsup/2 resistive divider on the +inp of the output amp, this sets the OPA output above 0v.
E
EDIT:
What is the part number of your A2D IC.?
Rickpercy87
Joined Nov 20, 2015
18
Of course, yes I see. However, with a 5V input should it not be 2.5V output instead of the 1.6V I am seeing?
The ADC is a cheap ADS1115 16bit ADC with programmable gain upto 16x, see datasheet below:
http://www.ti.com/lit/ds/symlink/ads1115.pdf
Max voltage it can tolerate is 5V which isn't a problem, but I was using the programmable gain which increased 1.6V to 12.8V or so.
RIch
ericgibbs
Joined Jan 29, 2010
21,649
hi 87,
If you have the space on your PCB, you could add another LM324 configured as a level shifter.
Will also look thru the ADC d/s, it may have a Vref offset feature.
E
EDIT:
No Vref, but it will accept +/-V inputs, so why not AC couple the amp output to the ADC input.??
