- Joined Jan 23, 2018
- 28,600
The pendant can easily control two single pole "double throw"relays with both a normally open (N.O.) contact and a normally closed (N.C.) contact.
The motor connects to the common connection on each relay, the DC supply positive connects to both N.O. contacts, and the DC supply negative connects to both NC contacts. So one relay operating drives "raise" and the other relay operating drives in the "Lower" direction, and if both are operated nothing happens at all. This exact scheme has been suggested and used many times on this forum. The brake-resistor string is connected directly across the motor, not only assuring correct operation, but also tending to dampen any switching spikes as the motor is switched on and off.
The challenge will be in locating a source of 48 volt coil relays with adequate contact current ratings. It may be that a separate source of relay coil power will be required.
