Harmonics
Cerkit
Joined Jan 4, 2009
287
Hi. If possible I would like a more intuitive explanation to how harmonics are generated regarding electrical power. Everywhere I read they just mention non linear loads, distortions or simply that harmonics of the fundamental ie 50Hz exist. To me this does not explain what happens at electron level which generates harmonics. I can visualize the fundamental so basically electrons oscillating back and forth a 50 times a second but how are the harmonics generated?
Thanks.
Jony130
Joined Feb 17, 2009
5,600
The harmonic will be generated if load current has shape different from sinusoidal.
For example exam current shape for a bridge rectifier circuit.
V1=10Vp≈7.07sk
I_V1≈0.177Ask
And FET harmonics analysis
Cerkit
Joined Jan 4, 2009
287
Thank you for your response. I guess in many ways this is the same as what I mentioned earlier, I understand the load being non linear ( ie containing various impedance rather than just pure resistive) and this results in a distorted current waveform, how does that result in harmonics? I can't make the connection :/
vk6zgo
Joined Jul 21, 2012
677
Any waveshape other than a pure sinewave (or cosine wave)may be regarded as a sinusoid at the repetition frequency of the waveform,plus a number of sinusoids at multiples of that frequency.
Every time you put a sinewave through a non-linear circuit such that the waveshape changes,these multiples of the "fundamental" frequency are created.
There is a classic graphical construction of a square wave from a fundamental & multiple harmonics which appears in most books on the subject.
You should be able to find it on the Internet.
Pure impedances do not cause harmonics,devices like rectifiers,saturable reactors & commutators,etc,which have a non-linear "transfer characteristic"are needed to do this.
35,180
What vk6zgo is trying to tell you, only sine waves have a single frequency.
Once you distort the sine wave into any other shape, you will generate other frequencies.
Ron H
Joined Apr 14, 2005
7,063
Here is a simple graphic that shows how a fundamental sine wave and its second harmonic, when summed, create second harmonic distortion.
