Harman/Kardon HK3270 no power
Thomas Bacon
Joined Mar 14, 2015
3
I received my HK3270 yesterday and it worked perfectly. But today when I turned it on from standby, it just died. I checked all of the fuses and they are all fine, there is no standby light at all even after unplugging it and plugging it back in.
Does anybody have the same problem?
22,112
Are you certain you understand the operation of the "Main Power Switch" and the "System Power Control" as detailed on page 8 under Front Panel Controls.?
Are you certain the unit is not plugged into a switched outlet?
Thomas Bacon
Joined Mar 14, 2015
3
Yes, the outlet is un switched and the main power switch is in the on position, but there is no standby power.
Hypatia's Protege
Joined Mar 1, 2015
3,228
Assuming you've already ascertained the presence of power at the outlet -- please check the fuse{s} with a VOM (open fuses don't always appear that way ;))
If its any consolation, the 'dark pilot light symptom' prophesys a brief and rewarding 'trouble-shoot' :)
Good luck! :)
Best Regards
HP
