Harman Kardon HK 3490 Amplifier Completely Dead, No Standby
thatoneguy
Joined Feb 19, 2009
6,359
Glad you got it working!
Might want to fix that transformer if it is just the loose filament in case you need it in the future.
NTL1991
Joined Jan 30, 2013
11
Good idea. I bought two of them just in case, but it wouldn't hurt to have a 2nd spare. My AVR 235 uses the same standby transformer as well.
Any idea what caused the primary to open up like that? Could a power surge or something of that nature cause it?
Nick
thatoneguy
Joined Feb 19, 2009
6,359
Nick
Could have been a bad joint at the factory, could have been used with a 1kW subwoofer which vibrate everything, could have been dropped, temp changes, but likely a temporary overload. If the MOV or TVS (Metal Oxide Varistor or Transient Voltage Supressor) weren't damaged, it could have been a result at running at near capacity for a long period. If it only happens once, I'd say "random unknown event", probably manufacturing defect that took a while to emerge.
tindel
Joined Sep 16, 2012
939
Great news! Glad you saved it from the landfill! That is always a good feeling! I've got a older HK that I'm trying to repair myself. It's problem is a little more difficult to track down - and I haven't quite figured out root cause, and I'm not sure I will until I get a scope on it.
Gdrumm
Joined Aug 29, 2008
684
Wou
I pulled T102 and checked for resistance. I have 5.5ohms of resistance between pins 3 and 4, the secondary side, and an open between the primary side, pins 1 and 2.
I got this receiver in a non-working state so I'm sure as to what it did before it went out. Not sure if it gave off any smoke, flames or anything of that nature.
So it looks like the transformer is dead? It's labelled "CLT5J033ZU", "SKP0204 - A161" and "9K1 SK" as well as "SP935002TF". There are a few sources for it on the web. Does this sound like the problem?
Thanks for all the continued support with this issue, I really appreciate it.
Nick
Would this be a candidate for a transformer that has a thermal fuse in it?
I have seen
So I replaced the standby transformer, put the unit back together, and plugged her in. Flipped the master power switch and the lovely amber LED came alive on the power button. Ahh!
Pressed the power button. It powered up with a nice click, the VFD lit up and it displayed the last audio mode selected. Then the VFD went blank and displayed "VOLTAGE PROTECT, CHECK DSP" and powered off.
Of course, not knowing the history of this unit, I came to the conclusion that something else was wrong with the unit as well, not just this bad transformer.
I glanced around inside and realized I forgot to connect one of the ribbon cables back to the DSP board. Plugged it in, and voila! Functioning perfectly!
I want to thank you guys for all the help. This is one of my first successful repairs on such a modern piece of electronics. It's very satisfying, to say the least. It's been a learning experience too, navigating through those schematics.
Thanks Again! You guys are the best!
-Nick
Gdrumm
Joined Aug 29, 2008
684
Oops!
I've seen some transformers with thermal fuses.
Maybe this one overheated and blew the thermal fuse?
If so, the problem may reappear with the new transformer.
