Harbor Frieght Battery charger "not"
JohnInTX
Joined Jun 26, 2012
4,787
If it uses foldback current limiting then the additional current drawn by a discharged battery would cut the output voltage to something below the charging voltage (13.8+) that a lead acid battery requires to charge. Little to no charge current would flow. Looking at the sketch in the manual shows no heatsinking on what looks like the pass devices so foldback makes sense to avoid overheating.
But will it still charge a discharged 12v 30 AH battery?
Not if I am right..
38,952
The reason they say its not for charging is because it likely is only is capable of providing a small (unspecified) current to provide a float-charge current to the battery. Thus it probably would charge a discharged 30AH battery but it could take several days.
But if it does have foldback limiting as John states then it could provide very little charge current to a discharged battery.
