Harbor freight cen-tech 750 watt Power supply schematic
dl324
Joined Mar 30, 2015
18,453
Not likely to be available. At under $50, it's a throwaway item.
This is probably borderline disallowed because lethal voltages are involved.
wayneh
Joined Sep 9, 2010
18,136
If a quick search doesn’t uncover a miracle, I’d put the odds against you as approaching a million to one.
Assuming you’re trying to do a repair, I’d do a thorough inspection under good lighting with a magnifying glass if needed. You might spot roasted components or other clues.
