- Joined Jul 18, 2013
- 30,884
So would it seem that a series of pulses raises the speed?
Sounds a little crude?
The typical T.M. controller ramps up the rpm, when the command is initiated.
Most now use PWM for speed command and have done away with the analogue pot.
Not really wise to disconnect and reconnect the motor, especially if there is a load attached.
The nicer version of boards is the MC2100 series, if you can find one.
