H Bridge protection when motor is acting as generator
enggricha
Joined May 17, 2014
89
Dear All,
I have a linear robot that moves along a single axis on a rail. This is driven by PMDC motors (100W/24V) on either side of the robot. Please see this video to under the type of product I am working on.
Problem: some times when the robot is climbing up an incline and for any reason slides back if the incline is too steep, the motors are acting as a generator and they fry the H bridge, Gate drive and also the rest of the circuitry.
Following is the H Bridge and Gate drive circuit. How can I protect against this?
MrAl
Joined Jun 17, 2014
13,833
What might be happening is the motor as generator is driving the DC buss up too high in voltage. Since the motor is the main load when being driven when the motor acts as generator there is no appreciable load to take the energy so the DC buss rises. The level to which it rises is hard to predict so you can try to measure it carefully allowing the device to slide back slowly.
You might have to apply a load to the DC buss or use some braking action with the transistors when the device slides back.
MaxHeadRoom
Joined Jul 18, 2013
30,860
If the motor is reverse rotating direction on the slide-back, then the generated voltage is opposing and is the reverse polarity fed from the bridge.
The result is very high current. And at worse is limited only by the low resistance of the armature.
Some way has to be carried out to prevent this reverse generation.
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,860
One method often used is a very low current sense resistor in the bridge circuit that is then fed to the processor via an op amp in order to advise the proc to shut down at a given current level.
Max.
MrAl
Joined Jun 17, 2014
13,833
Max.
The reverse transistor diodes cause any motor current, regardless of polarity, to be full wave rectified and applied to the DC buss as if an AC line input was full wave rectified and applied to the DC buss. So the only danger is a DC buss that goes too high such that the parts can not handle it.
MrAl
Joined Jun 17, 2014
13,833
Mr.Al can you give me some reference on how this can be done?
Well the main idea is you would apply some resistive load to the DC buss during times when the device is generating power, or you can look up some braking action methods done with H bridges.
For a braking action, sometimes just two lower transistors are turned on or two lower then two upper in order to distribute power between all the transistors/diodes.
MaxHeadRoom
Joined Jul 18, 2013
30,860
There are three possible conditions when they slide back, are the wheels still rotating in the right direction? Are they stalled? or are they being driven in the opposite direction?
Max.
dendad
Joined Feb 20, 2016
4,641
I think you need another pair of diodes, like D9 and D12, but going to the +V supply.
And then maybe a power zener clamp across the supply to limit the voltage.
MrAl
Joined Jun 17, 2014
13,833
Max.
Oh, well i wouldnt think the system would be damaged if the wheels were still turning in the right direction but i guess anything is possible.
MrAl
Joined Jun 17, 2014
13,833
Yes perhaps a shunt regulator that could handle high current high power.
Many power supplies are active high but not active low.
MrAl
Joined Jun 17, 2014
13,833
Then the generated voltage is of an opposite polarity to the applied voltage polarity.
Max.
And the diodes conduct with opposite polarity current right?
Or did he not add reverse diodes if the transistors did not have them?
If we remove all the transistors we are left with a full wave diode bridge with the motor connected to the AC input and the DC buss connected to the positive output (the cathodes) and negative output to ground (grounded anodes).
Or did you mean that the motor voltage reverses while the transistor bridge is still trying to power it with a normal regular polarity signal.
Alec_t
Joined Sep 17, 2013
15,158
Agreed. So it needs a current limiter added to keep the current within the capabilities of the FETs?
MrAl
Joined Jun 17, 2014
13,833
If in fact it does need that it also needs the power supply shunt regulator to keep the DC buss voltage within limits unless something else is done.
MrAl
Joined Jun 17, 2014
13,833
Yes, this was my implication.
Max,
Ok then i guess the next step would be to determine if the motor ever acts as a generator or not.
Assuming there are wheels, if the normal current/voltage is still applied when the motor is going up hill and then suddenly the wheels start to slip and it actually *slides* backwards then there would be no reverse current.
However, if the wheels have enough circumferencial friction then there would be reverse current/voltage. The current would then depend partly on the speed at which the motor 'rolls' backwards.
So perhaps some more measurements are in order.
This is interesting because for many applications the motor is modeled as a load only. Maybe we could take a look at how elevators in buildings deal with this.
Danko
Joined Nov 22, 2017
2,241
Try this circuit:
EDIT:
So, TS's problem is completely solved, H bridge, Gate drive and also the rest of the circuitry will not be fried.
Instead resistor BRAKE_LOAD may be connected solenoid coil, for solving some mechanical problem, in this situation.
