Gradual on and off Led lights
Ping pong
Joined Feb 13, 2022
91
I have a pair of led light bulbs on my car which draw 12v 0.5A power. I want these to gradually turn on when I power the leds and gradually turn off when they are switched off. The time for them to fade in/out should be between 3-4 seconds atleast. What type of circuit should I make for this.
The LEDs that I'm using are as follows with the gradual on/off feature on the white light only.
https://a.aliexpress.com/_mq7ZW2s
Ya’akov
Joined Jan 27, 2019
10,332
Since those lamps have integrated constant current drivers it may not be possible to dim them at all. The driver which is going to include some sort of DC-DC converter will have a particular frequency which will interact with PWM dimming and make the light flash.
You could test the lamps and see how they act on a variable power supply. If you can dim them by reducing the voltage without side effects then you might be able to work something out. I suspect, though, that you will find they have a narrow operating range and don't dim well or at all.
Can't tell until you try, of course; and you can't decide on a circuit until you know how the driver operates.
Ping pong
Joined Feb 13, 2022
91
The constant current driver is only connected to the amber leds so that there is no hyper flash. The white leds have a seperate cable for power which does not run through the driver.
Ya’akov
Joined Jan 27, 2019
10,332
However I could still try the fade effect by tapping into the dome light as that has the gradual turn on/off effect from factory.
You do need to know if any dimming strategy will work, and which one(s). If they don't have a CC driver, PWM is the obvious candidate.
This might be a good option. They caution there will be a brief flash when first powering up the device but if the power is applied, there is no flash. This doesn't seem to be a problem in your application since you are not going to have to have the lights turn on when you first turn on the ignition.
MrSalts
Joined Apr 2, 2020
2,767
The slow on/slow off gives a nice impression of high quality like some German luxury cars - a bright flash at each power up will certainly be a deal killer - unless the new look at feel of luxury is "the desirable" 'loose wire/bad connection effect'
28,458
Dimming and sow brightening might give the illusion of some quality, I find it obnoxious to have the ight come up sowy and fade away so that I am never sure that it wei switch off eventually. It makes no sense to me. An adjustable brightness can be useful, but not the fake "Luxury" gimmick..
Ping pong
Joined Feb 13, 2022
91
I'll probably end up buying this if every thing else fails. However, right now I am interested in DIY projects instead.
The way I have my LEDs set up, they turn on when I unlock the car and turn back off after 30seconds. They will also turn on when the car is in ignition, turning back off when I kill the ignition with a delay of 30 seconds
Wendy
Joined Mar 24, 2008
23,857
The larger the capacitor the longer it lasts, for your case I would use trial and error on small experiments to see what you want and what you like.
