I have a 250uF 25V cap w/ an ESR of 0.58 at 100kHz, from a mains rectifier. I'm just building up some experience with my LCR meter, so IDK, in some charts that's over. I guess if it's borderline I should replace it anyways.
What does parameter D show? Did you check the capacitor for leakage?I have a 250uF 25V cap w/ an ESR of 0.58 at 100kHz, from a mains rectifier.
Try this capacitor leakage current tester circuit.I should make a leakage current tester at low voltage,
