i generate sine wave using micro controller dac mcp4921 but i want change peak value according analog value so please help me
Why not then put the pot on the output of DAC.My guess.
They want to attach a pot to ADC and use it to control the amplitude of the sine wave coming out of DAC. I assume the uC has ADC. OP already told us that it does have DAC.
Also, increase button and decrease button can be used instead of pot+ADC combo.
While a valid concept, it introduces additional components (interference) into the desired signal. If the quality of the desired signal is not too critical, then putting pot at the output is perfectly valid way to do it.Why no
Thread starter | Similar threads | Forum | Replies | Date |
Generating a 38kHz Sine Wave | General Electronics Chat | 9 | ||
P | Generating High Resolution Sine wave Using PIC's PWM | Microcontrollers | 4 | |
M | Generating Sine Wave | Analog & Mixed-Signal Design | 84 | |
P | Generating 10kHz sine wave signal by PIC and DAC IC | Microcontrollers | 17 | |
E | generating sine wave | Analog & Mixed-Signal Design | 24 |
