generate a square wave with double pulse using arduino
Tarek1266
Joined Oct 18, 2019
60
Hi everyone ,
I would like to generate a square wave with double pulse like the one shown in the figure using arduino. any help ?
Regards,
Papabravo
Joined Feb 24, 2006
22,114
Give us an order of magnitude for the time intervals and some idea of the precision you need.
Are you familiar with how an "Output Compare" module works?
If you are and you have one available, then this sort of thing is pretty easy.
If not you have to work a bit harder.
Tarek1266
Joined Oct 18, 2019
60
the amplitude is 5V the frequency of the low frequency is 100Hz and the high one is 5kHz both with duty 50%
Rasterist
Joined Sep 15, 2020
I'm not going to write the code, but why not just set the pin high or low as necessary and wait the prescribed amount of time (t1, t2, or tb) before toggling it? Be sure to use the micros() command and not delay(). Since testing micros() will incur a small delay, this will take some fine-tuning.
Papabravo
Joined Feb 24, 2006
22,114
I still think you should use an the output compare module with maybe a 500 kHz clock. 50 ticks will get you 100 µsec and 5,000 ticks will get you 10 msec. Is that about right?
35,245
Transitions occur at 100μs marks.
Set the timer to interrupt every 100μs and use a phase counter to determine what to do at the output pin.
