General Logic
Ryan$
Joined Dec 14, 2018
178
Hi guys ; there's something I'm confused with and I would by your help to eliminate thats confusion and comprehend it;
Lets say I'm having a general function which it's like n(h)=2^h-1 ; lets assuming according to n=7 then h=20 "assuming !" , why saying what's h according to n=7 is the same saying what's n according to h=20! , how is that reflected logically between two statements of "saying" ?!
thanks!
Papabravo
Joined Feb 24, 2006
22,113
n(h) and h cannot be chosen independently if there is a functional relationship. If you specify one of the values, the other value is fixed. Your example posits a case which cannot exist. You cannot simultaneously have h=20 and n(h)=7.
If h=20 then n(20)= 1,048,575
If n=7 then h=3, because 2^(3)=8, and 8-1=7
wayneh
Joined Sep 9, 2010
18,175
To say it another way, you have one equation and one unknown and therefore zero degrees of freedom. Once the independent variable h is specified, there's no freedom to choose n. It's already defined by the choice of h and the equation.
Papabravo
Joined Feb 24, 2006
22,113
To say it another way, you have one equation and one unknown and therefore zero degrees of freedom. One the independent variable h is specified, there's no freedom to choose n. It's already defined by the choice of h and the equation.
Since the function has an inverse, it is also true that if you choose a value for n(h), then h is uniquely determined as well. Even if h is not an integer. It is the logarithm to the base 2 of (n(h) +1)
