I do apologize if this is not the right place to post.
1. There is a power factor improvement box currently improving power factor of some 750MVA load. The power factor that it is keeping is about 0.95. It is about 20-30 years old (the whole module). There is no documentation available about the type of capacitors being used or the DC voltages or ripples etc.
As the capacitor bank is old, I want to know if it is still safe to use those capacitors. If there needs to be a life cycle test / replacement for those. If so, what can I do ?
What sort of capacitors would they be if they are being used for that much load?
What is the average life cycle of those capacitors that are being used in industries (in general)
How often does one replace capacitors?
What happens if they get too old and are not replaced?
Do they explode? if so? what causes them to do so?
Any suggestions will be appreciated.
2. The voltages of a bus bar are same at each tapping. However, a few manuals that I read suggest that the voltages of a machine (lets say a boiler or a chiller) be taken on the machine and not on the bus bar. Is it possible for bus bar voltages to be different from the machine voltages? Incase of a fault?
3. What are the important components / electronics in a control panel / distribution panel (for machines / houses , control rooms) that should be checked/tested/maintained against a standard?
