I am working on an inverter circuit that will generate 110VAC 60hz but I do not know what to make the current rating. It will be used to charge laptops so I need to know what is the max you guys have seen for the input of a laptop charger. From the various charger circuits I have been able to get a hold of they usually Convert to DC then drop the voltage and increase the current.
So basically I am wondering if 110VAC 60hz 3Amps is overkill?
