Gated waveforms?
metermannd
Joined Oct 25, 2020
472
So, one thing I need to figure out is properly interfacing a 68HC11 MPU (Motorola) to a 8279 display controller (Intel).
The Motorola 68xx architecture makes use of a single R/~W line, while the Intel architecture calls for separate ~RD and ~WR lines.
The attachment shows the waveforms as measured in the piece of equipment I'm been dinking around with, and I want to see if this is what I'm supposed to have - in other words, whether the step of OR-ing the signals with the system clock is mandatory.
The first waveform is the R/~W signal as generated by the 68HC11.
The second is the ~RD signal; the R/~W signal is inverted then OR-ed with the system clock to generate this signal.
The third is the ~WR signal, which is just the R/~W signal OR-ed with the system clock.
Ian0
Joined Aug 7, 2020
13,278
In the dim and distant past, the RD and WR lines to interface Intel peripherals to 6502 and 6800 processors were generated from R/W and clock using a 74LS139, so I'd say yes - clock is required.
