Garage Door Motor Direction to Modbus Data Input
kent@idma
Joined Dec 28, 2020
20
Hi All,
This is a refresh of a post I did a few years ago, but we've now moved house and new Garage Doors / Data Inputs.
Previous Posting if Interested: https://forum.allaboutcircuits.com/...relays-based-on-dc-current-flow.175324/page-4 (36V DC Motor circuit. 12V DC supply for other circuit, 3V DC for GIPO inputs)
Objective: Want to detect if the motor is off or powered in a clockwise / anti-clockwise direction.
So the setup is:
1) Circuit 1: Garage Door Motor = 24V DC.
2) Circuit 2: 24V DC power supply, Modbus input can handle 3-30V
I've attached the circuit diagram that we eventually came to at the end. The key differences to last time are:
1) 24V DC motor (instead of 36V DC). Voltage while running drops to 6V for final opening/closing stage in my testing.
2) No need to reduce the return voltage, can keep at 24V.
Given this, my questions are:
Q) Given the lower voltage range of the motor, should I reduce R7 - 2.7K 1W (say to 2.2K 1W) ?
Q) Modbus Data Inputs can handle the full voltage so do I need to keep any of R1-R6 at all ?
Notes:
• I've assumed I keep the capacitor so when the motor speed changes it doesn't cause a false trigger.
• The 4N25 is what I used last time (and I have a couple left over).
Kent.
Dodgydave
Joined Jun 22, 2012
11,395
Does the modbus need a positive input or can it accept a low, if so you could just use the optocoupler to pull down with the collector and a 2.7K resistor 1/4W.
kent@idma
Joined Dec 28, 2020
20
Does the modbus need a positive input or can it accept a low, if so you could just use the optocoupler to pull down with the collector and a 27K resistor 1/4W.
As far as I can tell, yes. It has a 'COM' (which I've connected the -'ve to) and then the 16 inputs (which I've been connecting the +'ve to).
This is the guide I've been using for the software development: gecon-tcp-508n
This is the model I have: 12-channel Relay Output 16-channel Switch Input RJ45 Ethernet Modbus TCP Controller
If it worked fine before, I wouldn't change much. The RC filter section will provide a stable on/off signal to be detected by the software.
R7: 2.2K is my normal value for the 4N25 on 24vdc signals but you're needing to drive the LED at 6 volts, so a lower value (think about the dissipation of that limiting resistor) will likely be needed to cover the entire motor drive range for reliable signalling.
One of my typical 4N25 circuits.
You're driving an opto on the Modbus device so think about the drive current you need to supply from the filter.
From the link you posted.
ON level 5-30VDC,6mA@24VDC
OFF level 0-3VDC
kent@idma
Joined Dec 28, 2020
20
Then just use a pull up resistor and an optocoupler collector on each input,.
Thanks - that's was I was thinking also. See my updated circuit diagram below.
There were two key differences - the motor was 36VDC and the return was 3.6v maximum. Now I only have a 24VDC motor and the return requires at least 5VDC.
Okay - so I'll start with a 2.2K resistor and see how it goes. If I get a dropout too early when the motor is slowing down, then potentially drop this to a 2.0K resistor (bearing in mind if I drop too low I risk blowing the 6V LED in the OPTO when the motor is at full load).
OFF level 0-3VDC
My power supply is 24VDC / 15W (It's powering the Modbus, a 24V relay (230VAC out), 5x motion sensors and the other switched inputs. It should be overkill). I've just been connecting the +'ve directly to the DI's with no resistors so far and appears to be working.
So based on feedback from @Dodgydave and @nsaspook, this is my simplified circuit. Is this okay ?
