gain error in op amp buffer
whistler1
Joined Mar 10, 2023
I've built a non-inverting buffer using an MCP6002 powered from 5V.
I'm feeding a ramp voltage as Vin
I'm measuring Vin and Vout with an ADS1115 16 bit ADC
I'm puzzled as to how I can be getting a gain of >1 when I expect Avcl = Avol/1+Avol
38,932
If it is a simple gain of one follower configuration with the output directly connected to the minus input, then the anomaly is possibly due to the input offset voltage and the common-mode error of the op amp.
Also a rail-rail op amp operating from 0V to the supply voltage can have additional small offset errors at the extremes of the signal.
You are seeing very small deviations from the ideal.
StefanZe
Joined Nov 6, 2019
212
Input offsetvoltage und -current.
The ADS1115 will also add some error to your messurement. It has gain channel match of 0.05 to 0.1% and an offset channel match of 3LSB. This can also contribute to your gainerror.
