label1: btfsc PORTC,5
goto label2
btfsc FLAGS,6 ; debounce -\_
return ; exit routine, no action
incf count1,1
movf count1,0 ; get count
addlw DEBOUNCE_TIME ; CNT>16?
btfss CARRY
return ; no, so continue process
bsf FLAGS,6 ; set PRESSED flag
bsf FLAGS,0 ; set FLAGS.0 to update LCD
movf X,0
movwf K
movwf Out1
movf Y,0
movwf Q
incf Y
movf Y,0
movwf Out2
movf Q,0
sublw '9'
btfsc STATUS,Z
call loop1
label2:
btfss FLAGS,6 ; FLAG set? _/- debounce
goto label3 ; no so done
decf count1,1
btfss ZERO ; CNT=0?
return ; no so done
bcf FLAGS,6 ; yes so clear FLAG
label3:
clrf count1 ; clear counter, still bouncing
return
loop1: movlw '0'
movwf Y
movlw '0'
movwf Out2
incf X
incf Out1
movf K,0
sublw '9'
btfsc STATUS,Z
call loop2
return
loop2:
movlw '0'
movwf X
movlw '0'
movwf Out1
return
Do you know how to start a timer and get it to count?to be honest I still dont know to measure the time between two consecutive edges then determining time and taking reciprocal to find the frequency
I am saying this despite so many posts. I apologize but its the truth
I made the following attempt......
I connected a switch to one of the ports(PORTC,5) and then when I connected function generator I got the readings on LCD display but as per my code I could read 2,3,..... and not decimal
To your point of using 10 seconds, I need to reset the counter after every one second so it wont help
What you need to do is get some code working which waits for the input to change. So, the chip starts up and waits for the signal to go high. When it does this, it starts the timer at zero. It then waits for it to go low, and finally high again. As soon as the pin goes high a second time, it stops the timer and records the value. The value in the timer is the period of the waveform. The process can be repeated for more measurements. Get this part working, then you can work on frequency.yes i know how to define the timer
In fact I have defined a 10 ms timer and obtained 1 second interval from it
in my code
Its just that I dont know how to measure the time between two consecutive rising or falling edges of incoming signal
In my code which i got to execute with the help of switch connected to one of the ports
if i press the switch once per second it displays one and so on
but to get the value in decimal like 2.3 or 2.5 etc I think I have to use a different logic which I still couldn't figure out
Thanks for your help
movf count, W
call table
table
addwf PCL, F
retlw D'255' ;count=0 255 because result too big
retlw D'255' ;count=1 255 because result too big
retlw D'255' ;count=2 255 because result too big
retlw D'255' ;count=3 255 because result too big
retlw D'250' ;count=4
retlw D'200' ;count=5
retlw D'167' ;count=6
retlw D'143' ;count=7
retlw D'125' ;count=8
retlw D'111' ;count=9
retlw D'100' ;count=10
retlw D'91' ;count=11
retlw D'83' ;count=12
retlw D'77' ;count=13
retlw D'71' ;count=14
retlw D'67' ;count=15
retlw D'63' ;count=16
retlw D'59' ;count=17
retlw D'56' ;count=18
retlw D'53' ;count=19
retlw D'50' ;count=20
retlw D'48' ;count=21
retlw D'45' ;count=22
retlw D'43' ;count=23
retlw D'42' ;count=24
retlw D'40' ;count=25
retlw D'38' ;count=26
retlw D'37' ;count=27
retlw D'36' ;count=28
retlw D'34' ;count=29
retlw D'33' ;count=30
retlw D'32' ;count=31
retlw D'31' ;count=32
retlw D'30' ;count=33
retlw D'29' ;count=34
retlw D'29' ;count=35
retlw D'28' ;count=36
retlw D'27' ;count=37
retlw D'26' ;count=38
retlw D'26' ;count=39
retlw D'25' ;count=40
retlw D'24' ;count=41
retlw D'24' ;count=42
retlw D'23' ;count=43
retlw D'23' ;count=44
retlw D'22' ;count=45
retlw D'22' ;count=46
retlw D'21' ;count=47
retlw D'21' ;count=48
retlw D'20' ;count=49
retlw D'20' ;count=50
retlw D'20' ;count=51
retlw D'19' ;count=52
retlw D'19' ;count=53
retlw D'19' ;count=54
retlw D'18' ;count=55
retlw D'18' ;count=56
retlw D'18' ;count=57
retlw D'17' ;count=58
retlw D'17' ;count=59
retlw D'17' ;count=60
retlw D'16' ;count=61
retlw D'16' ;count=62
retlw D'16' ;count=63
retlw D'16' ;count=64
retlw D'15' ;count=65
retlw D'15' ;count=66
retlw D'15' ;count=67
retlw D'15' ;count=68
retlw D'14' ;count=69
retlw D'14' ;count=70
retlw D'14' ;count=71
retlw D'14' ;count=72
retlw D'14' ;count=73
retlw D'14' ;count=74
retlw D'13' ;count=75
retlw D'13' ;count=76
retlw D'13' ;count=77
retlw D'13' ;count=78
retlw D'13' ;count=79
retlw D'13' ;count=80
retlw D'12' ;count=81
retlw D'12' ;count=82
retlw D'12' ;count=83
retlw D'12' ;count=84
retlw D'12' ;count=85
retlw D'12' ;count=86
retlw D'11' ;count=87
retlw D'11' ;count=88
retlw D'11' ;count=89
retlw D'11' ;count=90
retlw D'11' ;count=91
retlw D'11' ;count=92
retlw D'11' ;count=93
retlw D'11' ;count=94
retlw D'11' ;count=95
retlw D'10' ;count=96
retlw D'10' ;count=97
retlw D'10' ;count=98
retlw D'10' ;count=99
retlw D'10' ;count=100
retlw D'10' ;count=101
retlw D'10' ;count=102
retlw D'10' ;count=103
retlw D'10' ;count=104
retlw D'10' ;count=105
retlw D'9' ;count=106
retlw D'9' ;count=107
retlw D'9' ;count=108
retlw D'9' ;count=109
retlw D'9' ;count=110
retlw D'9' ;count=111
retlw D'9' ;count=112
retlw D'9' ;count=113
retlw D'9' ;count=114
retlw D'9' ;count=115
retlw D'9' ;count=116
retlw D'9' ;count=117
retlw D'8' ;count=118
retlw D'8' ;count=119
retlw D'8' ;count=120
retlw D'8' ;count=121
retlw D'8' ;count=122
retlw D'8' ;count=123
retlw D'8' ;count=124
retlw D'8' ;count=125
retlw D'8' ;count=126
retlw D'8' ;count=127
retlw D'8' ;count=128
retlw D'8' ;count=129
retlw D'8' ;count=130
retlw D'8' ;count=131
retlw D'8' ;count=132
retlw D'8' ;count=133
retlw D'7' ;count=134
retlw D'7' ;count=135
retlw D'7' ;count=136
retlw D'7' ;count=137
retlw D'7' ;count=138
retlw D'7' ;count=139
retlw D'7' ;count=140
retlw D'7' ;count=141
retlw D'7' ;count=142
retlw D'7' ;count=143
retlw D'7' ;count=144
retlw D'7' ;count=145
retlw D'7' ;count=146
retlw D'7' ;count=147
retlw D'7' ;count=148
retlw D'7' ;count=149
retlw D'7' ;count=150
retlw D'7' ;count=151
retlw D'7' ;count=152
retlw D'7' ;count=153
retlw D'6' ;count=154
retlw D'6' ;count=155
retlw D'6' ;count=156
retlw D'6' ;count=157
retlw D'6' ;count=158
retlw D'6' ;count=159
retlw D'6' ;count=160
retlw D'6' ;count=161
retlw D'6' ;count=162
retlw D'6' ;count=163
retlw D'6' ;count=164
retlw D'6' ;count=165
retlw D'6' ;count=166
retlw D'6' ;count=167
retlw D'6' ;count=168
retlw D'6' ;count=169
retlw D'6' ;count=170
retlw D'6' ;count=171
retlw D'6' ;count=172
retlw D'6' ;count=173
retlw D'6' ;count=174
retlw D'6' ;count=175
retlw D'6' ;count=176
retlw D'6' ;count=177
retlw D'6' ;count=178
retlw D'6' ;count=179
retlw D'6' ;count=180
retlw D'6' ;count=181
retlw D'5' ;count=182
retlw D'5' ;count=183
retlw D'5' ;count=184
retlw D'5' ;count=185
retlw D'5' ;count=186
retlw D'5' ;count=187
retlw D'5' ;count=188
retlw D'5' ;count=189
retlw D'5' ;count=190
retlw D'5' ;count=191
retlw D'5' ;count=192
retlw D'5' ;count=193
retlw D'5' ;count=194
retlw D'5' ;count=195
retlw D'5' ;count=196
retlw D'5' ;count=197
retlw D'5' ;count=198
retlw D'5' ;count=199
retlw D'5' ;count=200
retlw D'5' ;count=201
retlw D'5' ;count=202
retlw D'5' ;count=203
retlw D'5' ;count=204
retlw D'5' ;count=205
retlw D'5' ;count=206
retlw D'5' ;count=207
retlw D'5' ;count=208
retlw D'5' ;count=209
retlw D'5' ;count=210
retlw D'5' ;count=211
retlw D'5' ;count=212
retlw D'5' ;count=213
retlw D'5' ;count=214
retlw D'5' ;count=215
retlw D'5' ;count=216
retlw D'5' ;count=217
retlw D'5' ;count=218
retlw D'5' ;count=219
retlw D'5' ;count=220
retlw D'5' ;count=221
retlw D'5' ;count=222
retlw D'4' ;count=223
retlw D'4' ;count=224
retlw D'4' ;count=225
retlw D'4' ;count=226
retlw D'4' ;count=227
retlw D'4' ;count=228
retlw D'4' ;count=229
retlw D'4' ;count=230
retlw D'4' ;count=231
retlw D'4' ;count=232
retlw D'4' ;count=233
retlw D'4' ;count=234
retlw D'4' ;count=235
retlw D'4' ;count=236
retlw D'4' ;count=237
retlw D'4' ;count=238
retlw D'4' ;count=239
retlw D'4' ;count=240
retlw D'4' ;count=241
retlw D'4' ;count=242
retlw D'4' ;count=243
retlw D'4' ;count=244
retlw D'4' ;count=245
retlw D'4' ;count=246
retlw D'4' ;count=247
retlw D'4' ;count=248
retlw D'4' ;count=249
retlw D'4' ;count=250
retlw D'4' ;count=251
retlw D'4' ;count=252
retlw D'4' ;count=253
retlw D'4' ;count=254
retlw D'4' ;count=255
