FREQUENCY CALCULATION 3525
MATT838383
Joined Jul 31, 2019
144
Hello everybody i am trying to set the frequency of a 3525 with this formula 1/(1,10^-9*(0,7*15000+3*22))=94643HZ
where ct =µf
rt=ohms
my results=-1,05!
thank you for helping me!
ronsimpson
Joined Oct 7, 2019
4,758
Your number is close to -1 so there must be at least 2 problems. Should be positive and should be a large number.
"^-9" I think you are not doing that right. 1.10^-9 is a very small number.
Where did you find the formula? What is a 3525?
Irving
Joined Jan 30, 2016
5,195
That's not a formula, its a numerical expression. I get 86039Hz if you take 1.1E-9 for the first element in bold, though I can see it could be misread as 1 x 10E-9.. What was your value for \(C_t\)?
The formula is:
\(f(Hz) = 1/C_t (0.7R_t + 3R_d)\), where \(R_t\) and \(R_d\)are in ohms and \(C_t\) in F
With \(R_t\) and \(R_d\) in ohms and \(C_t\) in uF the result is in MHz
Irving
Joined Jan 30, 2016
5,195
No, you must get the top & bottom right, its:
\(f(MHz)=1/C_t(0.7R_t+3R_d)\), where \(R_t\) and \(R_d\) are in ohms and \(C_t\) in uF NOT
\(f(MHz) = 1/C_t . (0.7R_t + 3R_d)\)
f = 1/( 0.001 * (0.7 * 15000 + 3 * 22)) = 0.0946431MHz = 94.64kHz
NOT
f = 1/(0.001) * (0.7*15000 + 3 * 22) = 10566000 ???
