Freescale MC9S08QG8 microcontroller project help
johhny101
Joined May 5, 2014
2
This semester I had my first microcontrollers class and cant seem to get enough of it. For the classes final project my professor gave each student the choice between 4 different projects. I decided that I wanted to go through and do them all for practice. The program that I am working on takes a string of ASCII characters and sends them over the SCI and converts it to morse code. The following code is what I have done so far but I am having trouble with the last ISR and dont really have a clue how to do what the instructions says. The part I am confused about is under the line of asterisks.
Any help would be appreciated. Thanks!
Rich (BB code):
#include <hidef.h> /* for EnableInterrupts macro */
#include "mc9s08qg8.h" /* include peripheral declarations */
#define RBUFSIZ 80
#define BAUD 9600
#define SCIBDVAL (1000000+BAUD)/(2*BAUD)
#define INITIAL_UNIT 25
#define Morse_Unit 25
    extern unsigned const char morsecode[];
    static unsigned char UnitDelay=INITIAL_UNIT, UnitCountDown=INITIAL_UNIT;
    static unsigned char MorseState=0;
    static unsigned char rcvbuff[RBUFSIZ] = "hello there";
    static unsigned char *rcviptr, *rcvoptr; // my code
    static unsigned char chara;
    static unsigned char codechar;
void main(void) {
    unsigned int i;
    SOPT1 = SOPT1_BKGDPE_MASK+SOPT1_RSTPE_MASK;
    PTAPE = 0xff;
    PTBDD = 0xff;
    ICSTRM = NV_ICSTRM;
    for (i=0;i<400;i++); /* delay 2 ms (at 4 MHz) */
    ICSC2 = 0;  /* up speed to 8 MHz */
    PTADD_PTADD0 = 1; /* set pin 16 as an output */
    PTADS_PTADS0 = 1; /* make capable of driving LEDs */
    SCIBD = SCIBDVAL;
    SCIC2 = SCIC2_RE_MASK+SCIC2_RIE_MASK;
/* Correctly complete these 2 lines to produce 250 TOF interrupts per sec */
    MTIMSC = 0b01010000;
    MTIMMOD = 249;
/* The following configures TPM Channel 0 to toggle pin 16 */
    TPMC0SC = 0x14;
/* The defalult for all other registers is okay except */
/* the modulo register sets the frequency of the tone produced */
/* on pin 16 according to the formula: freq = 8000000/(2*(TPMMOD+1)) */
   TPMMOD = 300;  /* pick a value for a freq between 500-2000 */
    rcvoptr = rcvbuff;
    rcviptr = rcvbuff+11;  /* "hello there" is in buff */
    EnableInterrupts; /* enable interrupts */
    for(;;);   /* loop forever leaving all work to the ISRs */
interrupt VectorNumber_Vmtim void mtimisr() {
    static unsigned char charcode;
    MTIMSC_TOF = 0;
    if (--UnitCountDown==0)
       UnitCountDown = Morse_Unit; // default delay will be 1
       switch (MorseState)
          case 0:
            if (rcvoptr != rcviptr)
               chara = *rcvoptr++;
               if (rcvoptr > rcvbuff+RBUFSIZ)
                  rcvoptr = rcvbuff;
               if (chara ==' '){
                {UnitCountDown = 3*Morse_Unit; break;}
               codechar = (unsigned char)morsecode[chara];
               startsound();
               MorseState=1;
               if (codechar & 0x80==0x80)
                /*most significant bit of codechar is 1*/
                  UnitCountDown = 3*Morse_Unit;    //UnitCoundDown changed from    MorseCountDown
            break;
          case 1:
            /*insert code to stop sound and advance to state 2*/
            stopsound();
            MorseState = 2;
            break;
          case 2:
            /* the code here first shifts codechar one bit left */
            codechar = (codechar << 1);
            /* then it checks if it is 0x80 indicating char complete */
            if(codechar = 0x80)
            MorseState = 0;
            /* follow the state arrow indicated from the above result */
                /* if char not complete code is a copy of the four lines */
            /* starting with startsound() from state 0 above */
              else{
              startsound();
              MorseState = 1;
               if ((codechar & 0x80)==0x80){
          break;
void startsound() {
/*  add code to start sound by starting TPMCNT counting
    by setting the the CLKSA bit in TPMSC.  This selects
    the bus clock as the clock for the counter. */
            TPMSC_CLKSA = 1;
void stopsound() {
/*  add code to stop sound (clear CLKSA which selects nothing
    as the clock for the counter thus disabling it */
           TPMSC_CLKSA = 0;
interrupt 15 void scirisr() {
    static unsigned char charb;
    charb = SCIS1;
    charb = SCID;
 //This part below is what I am having Trouble with.
 /* test to see if the character is one of any special characters you picked */
    /* to vary the speed or tone frequency of the Morse code being produced */
    /* if it is do the specified change.  The speed is modified by changing the */
    /* value of MorseUnit.  The freq of the tone is modified by changing TMPMOD. */
    /* if not command char, place SCID value in the circular receive buffer */
/* complete the constant table below */
  unsigned const char morsecode[] =
    {0,0,0,0,0,0,0,0,  0,0,0,0,0,0,0,0,
     0x80,0,0,0,0x13,0,0,0,                          /* sp - - - $ - - - */
     0,0,0,0,0xce,0,0x56,0,                          /*  - - - - , - . - */
     0xfc,0x7c,0x3c,0x1c,0x0c,0x04,0x84,0xc4,        /*  0 1 2 3 4 5 6 7 */
     0xe4,0xf4,0xe2,0xaa,0x00,0x00,0x00,0x32,        /*  8 9 : ; - - - ? */
     0x00,0x60,0x88,0xa8,0x90,0x40,0x28,0xd0,        /*  - A B C D E F G */
       0x08, 0x20, ox78, 0xb0, 0x98, 0xe0, 0xa0,       /*  H,J,K,L,M,N,O*/
     0xf0,0x98,0xb8,0xc8,0,0,0,0,0,                  /*  X Y Z - - - - - */
     0x00,0x60,0x88,0xa8,0x90,0x40,0x28,0xd0,        /*  - a b c d e f g */
       0x68, 0xd8, 0x50, 0x10, 0xc0, 0xc0, 0x30,       /*p, q, r,s,t,u,v*/
     0x18, 0x60,0x98,0xb8,0xc8,0,0,0,0,0};           /*  x y z - - - - - */
/* end of source file */
ErnieM
Joined Apr 24, 2011
8,415
" //This part below is what I am having Trouble with. "
Please define "trouble." If you mean it does not compile check line 152: "ox78" should be "0x78".
johhny101
Joined May 5, 2014
2
Sorry about some of the sloppy code. I wrote it in a text editor since I am doing this from my house and dont have a system that is running Windows and Codewarrior does not support unix like systems. What I cant figure out is how to change the length of the tone and produce a "dit" or a "dah" when I get a certain Character using the Constant table
