Hi, I have a question, it's possible that a drone with a camera, to make an example, of the Foxeer "legend1" that has a resolution between 720-1080, maximum, can I transmit images in real time to FPV glasses? If is true, the type of signal will be a bit heavy, so how do I figure out which signal transmission board to take? Also for that for reception ... thank you very much, in advance.
