Forward voltage Vf for diode...
Externet
Joined Nov 29, 2005
2,681
Hi.
Assuming 300mVf for a germanium diode D; how does rectification work on a 1 microvolt antenna signal ?
DickCappels
Joined Aug 21, 2008
10,661
Just to add to AalbertHall's explanation, the forward voltage specification applies to a specific current and temperature. This is true of all rectifier types as far as I know and can imagine.
38,943
A diode has an exponential relation between forward voltage and current, so will still conduct current at anything above zero volts.
The given "typical" forward voltages of diodes are usually at around a mA of so of current.
