FM receiever using psoc
maheshkumar0459
Joined Sep 7, 2013
5
I want to build a Fm receiver using PSoC-3 kit. The main heart of FM receiver is PLL(Phase locked loop) whicch is a feedback loop. FM frequency is 88-108MHz
but PSoC max frequency is 12-67MHz. so how can i increase PSoC frequency.
Will this project work out??
Give ideas to work out this..
Thanks in advance..
33,141
So you aren't trying to build an FM receiver and happen to think of using that PSoC-3 kit, but rather you have to use the PSoC-3 kit and happen to think of building an FM receiver. That's an important distinction since it completely redefines what your problem is.
Why not try finding a project that matches the capabilities of the parts you are required to use?
maheshkumar0459
Joined Sep 7, 2013
5
Thanks for your reply..
If i can build PLL using PSoC then i can make it as FM receiver easily as PLL is main block of FM receiver. So i wanted to build FM only..
But how can i increase the frequency of PSoC from low frequncy to high frequncy ie:88-108MHz..
If i can increase frequency then FM receiver can be done easily..
