Fix for Dremel Workstation Drill Press When Using Carbide Drill Bits
MrAl
Joined Jun 17, 2014
13,791
The short answer is china! The vendor I bought mine from on eBay is gone but here is the same model also on ebay. Drill Press Stand for Dremel Rotary Tool Woodworking and Jewelry Making Machine 7445005943984 | eBay
Probably ~6 vendors selling this model all within 5USD of each other.
You should also look at this. I haven't bolted mine to the base but simply use it loose with the part clamped in... Has nylon jaws for things like glass etc.
You might also look at the benchtop drill press that Harbor Freight sells with a 1/3hp motor and at least a 1/4" chuck (no specs.).
8 in. 5 Speed Bench Drill Press (harborfreight.com)
Not sure if i could use a vise as i would mainly drill flat boards. Nice vice though.
That drill press looks good i'm going to have to take a look at that and maybe recommend it to the neighbor as he really wanted a regular drill press not a combination drill press and milling head. I love that combo though makes a really tough drill press which would be really great for carbide bits of the smallest sizes.
I see they make sizes even smaller than #75. I think #90 and that must be hair thin. Never needed that though.
SamR
Joined Mar 19, 2019
5,535
My pin vise HSS bits are metric with smallest being 0.3mm and I have Dremel chucks for it. Also diamond and HSS bits down to 1mm and imperial down to 1/16". I also keep a jeweler's saw and assorted blades in my toolbox. Lots of nylon, brass, and SS brushes for the Dremel along with various stone and grit grinding bits and some polishing/buffing bits. I still need a very small miter box and will order one now that I remember I need it! On order!
bassbindevil
Joined Jan 23, 2014
924
I never thought about holding it steady i guess because i needed one hand on the lever and used the other hand to hold down the board and move it around for different hole locations.
I was able to eliminate the slop in the Stichling drill press by just applying some sideways pressure to the handle, so I still had a hand free to hold the PC board. The rack-and-pinion Dremel 210 press is the way to go if you can find one, and either have a working vintage Dremel tool or can make an adapter.
MrAl
Joined Jun 17, 2014
13,791
Hello again,
Oh that's funny, i have a very small miter box too i just used it yesterday to make a mod on my desk cell phone holder, which i made custom. Really comes in handy and does a great job. It's funny they make one that small, about 6 to 8 inches long, and the saw is just about that too. I've had it for over 25 years.
MrAl
Joined Jun 17, 2014
13,791
Oh, so that's how you did it. Mine was a bit different and I wasn't even sure any fix would work so I took a chance.
