Filtering noise from sound file
flames
Joined Jun 24, 2009
2
Hi, i am a freshmen in university and would like some help regarding a circuits project.
I have been given 2 .wav files. One with a clear speech and another with the same speech but with a noise in the background.
Our project is to isolate the frequency of the noise and design a filter, (low pass, high pass or band pass) using capacitors, resistors and inductors only, to filter out the noise and play the clean speech.
Software at my disposal is mutlisim as we have not be allowed or trained to use matlab or any other software.
We can use any software to identify the frequency of the noise.
Here are the files:
Speech with noise: http://www.tempfiles.net/download/200906/46197/noisyspeech.html
Clean speech: http://www.tempfiles.net/download/200906/46198/cleanspeech.html
I need to create the filter physically (on a breadboard) and on multisim.
any help would be appreciated
Thank you
bertus
Joined Apr 5, 2008
23,009
In the "old days" the phone companies have said that the human voice frequency range is between 300 and 3000 hz.
To see what frequency the noise is you can use the FFT function of some software.
I use audacity a freeware program available for windows, mac and linux.
Greetings,
Audioguru
Joined Dec 20, 2007
11,248
The speech is buried in noise that has the same frequencies. If you filter out the high frequencies then the important consonants of speech will be filtered out and the speech will be impossible to understand like ducks quacking.
