FFT LED Spectrum analyzer on PIC32
t06afre
Joined May 11, 2009
5,934
I have not followed this thread for a while. But to be general. A chip has maximum current for each IO pin. But also for the total current. So if you have a 40 pins PIC. It is no problem to control a few LEDs. But you will not be able to use all the ports to turn LEDs on at the same time. Say you will have 35 pins available as output pins. using 20 mA pr LED. Will give a total current of 0.7A to much for a PIC
stefan646
Joined Dec 16, 2011
28
I understand that, but I have been advised to control the hole matrix by turning on only one led and surfing the matrix at very hight speed. In this case my logic says that I don't need transistors.
So how is easier to write the code to control the matrix? By turning only one led at a time or by turning on more led's?
stefan646
Joined Dec 16, 2011
28
I finish all the led's connection and solder all the HC595 wire.
The problem is that if I want to light a led(simple, without the HC595) , in many cases other 1-7 will light as well(with a more week brightness of course ).
I measure with a multimeter and i have no surtcircuit.
What is then the problem or how I can detect it?
Sorry for the poor quality of the photo, I will make others on a better quality.
Dmax
Joined Feb 28, 2015
did you ever get this project working ? , I think you should have started with fewer LEDs , I'm playing around with something like this right now
35,173
The TS was last heard from three years ago. I don't think he is listening anymore.
Start a new thread if you want some follow up.
