Ferric chloride again :(
Robin Mitchell
Joined Oct 25, 2009
819
Hi everyone,
Just to make sure with people who have used ferric chloride, what will happen if it gets on my hands? some websites say that it does nothing and some say it burns.... so what is the truth? Is it letahl? Is it harmless to organic things?
Markd77
Joined Sep 7, 2009
2,806
Pick up some disposable rubber gloves and avoid the problem. Eye protection is a good idea too.
I've had some on my hands for a short time, I rinsed it off straight away and it didn't seem to do anything at all, but best to avoid it.
beenthere
Joined Apr 20, 2004
15,819
Other than stains, it's pretty harmless. I have reached into my sprayer tank to rescue a PCB that fell off the holder. I had the stuff up past my wrist. I rinsed it off - no burns or stains on my skin and nails. I would rate it as safer than HCl. I have been using the same batch for 8 years now, so it's economical to use.
shortbus
Joined Sep 30, 2009
10,049
I think the staining comes from the type of water used, can't prove it though. When I used distilled water it did not stain. The next time I mixed with tap water and it did stain. The same bottle of ferric chloride powder was used in both batches. A reaction with minerals in the tap water? Don't really know.
BillO
Joined Nov 24, 2008
1,001
Ferric Chloride itself is not very toxic. In solution in water, it can be quite acidic and may irritate sensitive skin. However, if you are using this to etch circuit boards, the by-products include Ferrous chloride and copper(II) chloride (CuCl2). Copper(II) chloride is toxic.
I'd advise the use of rubber gloves and tongs.
Georacer
Joined Nov 25, 2009
5,182
And by all means watch out for those stains! They don't come off at all at porous surfaces. My bathtub still has pale yellow spots after only one use of the mix.
jpanhalt
Joined Jan 18, 2008
11,087
I think he mean spots. Etching in the bath tub sounds perfectly reasonable to me. At least, it is not likely to contaminate food. Ferric chloride will almost instantly stain or etch stainless steel or ceramic surfaces. There might be ways to remediate the ceramic stains with ammonium citrate complexes (i.e., to form ferric ammonium citrate) or oxalic acid, but that is just a guess. It may just turn it another color.
John
Georacer
Joined Nov 25, 2009
5,182
You etched circuit boards in your bathtub??
:eek:
I knew that it would be stain-prone, so I had running water flow on the bathtub floor when I poured the FeCl out. But some drips flew on the bathtub walls and spots formed there.
Where else could I have poured it?
jpanhalt
Joined Jan 18, 2008
11,087
Hi Georacer:
I do "it" in the kitchen sink. But then I don't have a wife here to complain. I think the bath tub is a good place. It is certainly better than the toilet. Try the remedies for iron stains I suggested.
John
magnet18
Joined Dec 22, 2010
1,227
Ok, pouring makes more sense. I thought you'd just soaked the boards in the tub. I'm pretty sure you'd never get that amount of stains out. :)
Wendy
Joined Mar 24, 2008
23,811
You guys are crazy, copper pipes and FeCl?
I use tupperware, toss in some wire, and seal it with tape, then throw it away.
The acid I pick weed I don't like.
Georacer
Joined Nov 25, 2009
5,182
I don't think that it will harm the piping in such a diluted state, Bill. I make sure to pour it over a fully opened faucet. Not that I etch at home any more. When I design something, the scale usually demands a PCB service.
Thanks for the advice, John!
Wendy
Joined Mar 24, 2008
23,811
The stuff is designed to eat copper, dilution helps but it will still react. So do drain cleaners, but at least you are getting a service with it. I doubt the water treatment plants are very equipped to handle it either. Replacing pipes is very, very expensive.
Technically FeCl is a salt, just like NaCl (table salt). It is very reactive though, so I give it something to chew on to reduce the reactivity over the long term.
Hydrochloric acid is just chlorine and hydrogen, and H2O2 is oxygen and hydrogen. I have no problem getting rid of small quantities in my yard. I stay away from any metal though.
jpanhalt
Joined Jan 18, 2008
11,087
First, very few of us have copper drain pipes. Second, contact time and concentration make a huge difference. And finally, water treatment plants are the major industrial user of ferric chloride in most cities. They are more than equipped to handle it. That add it to the sewage (http://en.wikipedia.org/wiki/Ferric_chloride).
HCl plus NaCl is pretty reactive too and will etch many metals, including stainless steel. It's the high chloride concentration that is the culprit. (Agua regia is the same principle and will dissolve gold.) Giving it "something to chew on" only increases the amount of copper pollution you are adding. If you are going to dump it, just dilute and dump it.
John
Wendy
Joined Mar 24, 2008
23,811
PVC may be the main material in that neck of the woods, but I've only seen copper plumbing around here. PVC may even be the main material around here too, I'm not a contractor, and I live in an old house with thin pipes (thin from use). From what I've seen the service pipes (water and sewage) are also metal.
I hadn't heard about FeCl used in water treatment plants. I think it was used for ink during midevil ages.
I've mentioned it before, but some dissolved FeCl did a number on my tools in a supposidly sealed plastic container from the fumes. I'll be keeping it away from my pipes in any form.
