Fender Fronman 65r guitar amp
Status
Not open for further replies.
bgutiar
Joined Aug 25, 2022
6
I have a Fender Frontman 65r. When i turn it on it makes an explosive noise. after about 30 seconds it works fine. Any ideas?
35,217
Welcome to AAC!
Describe the sound of "explosive noise". How long does the sound last?
A "thump" on power-on and power-off is common with solid-state amplifiers. This is the sound made when the output coupling capacitor to the speaker charges and discharges.
The Fender Frontman 65R is DC coupled to the loudspeaker. There is no coupling capacitor.
Hence the noise is originating from someplace else.
Typically, high power amplifiers have a speaker relay that is energized after a few seconds. This is to allow for a safety check and avoids the turn on "thump".
35,217
Sounds like a warm up issue in the main power supply.
The usual suspects are the power supply filter capacitors.
I will have a look at the circuit schematic later when I get a chance.
35,217
We've got some serious diagnostics ahead of us.
Here is what we know.
1) Pop and buzz, lasts for 30 seconds.
2) With or without input plugged in.
More tests
1) After the buzz goes away, what happens when you turn it off and on again within 2 seconds? Does the pop and buzz reappear?
If not, how long do you have to wait with the power off for the buzz to reappear?
2) Turn VOLUME and DRIVE to 0.
Set CH SELECT button OUT.
Is the buzz still there on power on?
3) Insert a 1/4" patch cable into the FOOT SWITCH.
Is the buzz still there?
bgutiar
Joined Aug 25, 2022
6
More tests
1 same buzz
2 yes clean channel and dirty
3 same with foot pedal or not
35,217
There is not much here to make a diagnostic.
Normally, one would examine the power rails with an oscilloscope during warm up .
The first suspects to replace are C69 and C70, 47μF electrolytics. Install 25V-63V types.
The next suspects would be C65 and C66, 2200μF electrolytics. Install 50V-63V types.
Status
